error code 000002-0003 cannon ir 3200 need some help please tech guys
  • rdc
    • 53
    [Error Code] error code 000002-0003 cannon ir 3200 need some help please tech guys
    turn on machine and code comes up for 15 seconds or so and machine turns off.help please.thanks ahead of time.
  • teckat
    • 16083
    Re: error code 000002-0003 cannon ir 3200 need some help please tech guys
    Inspect unit before an ERROR CLEAR
    E002 - inadequate rise in temperature of fixing unit
    = 0003/ The output of the non-contact thermistor TH1
    remove fix unit > check for paper wrap around roller
    service mode
    COPIER>FUNCTION<CLEAR>ERR
    Clears error codes.
    (Cleared error codes: E000, E001, E002, E003, E719)
    Operation method
    1) Select this item, and press the OK key.
    2) Turn the main power OFF/ON.
    • SCREWTAPE
      East Coast Imaging
      • 3396
      Chances are...
      Yes, you can clear out the code and recover.
      Or,
      You might need to replace your fuser in time.
