need more help what is this code ?bad drum,,,thanks again
another code ir 3200 e000012 0001
Re: another code ir 3200 e000012 0001
Probably a missing 24v issueDrum ITB Motor (M1) --check for 24v
++++ Check and/or replace the Double Switch PCB Assembly (FG6-9015-000) located in the rear of the copier behind the DC controller.
24V I/L supply (to the ITB Motor (M1)) passes through Fuser Carriage switches MSW 5/6, Front Cover Open/ Closed detection switches MSW 1/2, and Manual Feed unit Open/ Closed detection switches MSW 3/4.
If the voltage is not present at the motor, trace it back to the fuse pcb.
As the machine starts initial rotation, an E012-0001 error occurs.
24 V DC is measured at J71 pin 1 and 0 V DC is measured on pin 3 (normally 24 V DC is measured on both pins). The 24 Volts on pin 1 is fed through all 6 interlock switches and back to pin 3. If you're missing the the voltage on pin 3, check the interlocks for an "open".
Workaround :
In this case there was an open in the front door interlocks.
Below is a diagram of the printer with the interlocks highlighted in red.
**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Did u check all door switches ?
Any missing or low voltage at a switch will cause voltsge drop and contribute to error**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
