Canon IR3245i Finisher issue
  • teckat
    • 16083
    #16
    Re: Canon IR3245i Finisher issue
    If u still receive remove paper -- the sensor needs to be check--
    • IkeW0491
      • Oct 2013
      • 172
      #17
      Hi Tekcat,
      I have the one similar to the top pic,
      But I have two paper trays on the finisher.
      I have checked the flags on both trays, they both are functioning normally and do not appear to have any foreign matte in their crevices either.
      Still not sure what is causing the issue.
      Thanks again.
      IKE
      Originally posted by teckat
      this may be your issue on OUTPUT TRAY MESSAGE/ a stuck flag here will assume paper is present in location
      Look at this pic below- if this is your set up/ look at outline in RED-
      Check this OUTPUT TRAY location for a stuck flag
      [ATTACH=CONFIG]22500[/ATTACH]
      or is this your set-up below
      [ATTACH=CONFIG]22501[/ATTACH]
      • teckat
        • 16083
        #18
        Top pic shows external two tray finisher --Do u seethe red outlined area ? That is output tray i mean
        • IkeW0491
          • Oct 2013
          • 172
          #19
          Yeah Tek,
          I Checked the flags, they are Not sticking anywhere
          I don't have the 2 tray external finsher.
          Mine has the "S1"fnisher I think.
          It is built into the machine and you have to slide it out to work on it.
          Has 2 trays on it and they stick partway out the side of the machine just past the cover for the ADF.
          Actually Tek, I do have the bottom pic setup.
          Sorry These pics are small and hard to see details on them.
          • teckat
            • 16083
            #20
            Ok -- it is a S1
            Like i said- just because u can move flags -- this does not determin if a sensor is good or bad unless checked in service mode or from the connection to it's signal pcb.
            If u still receive that message to remove paper--u need or a tech needs to check signals
            • IkeW0491
              • Oct 2013
              • 172
              #21
              Ok so we will have to see if its a sensor or the PCB.
              I am banking on the PCB, because I also got error codes
              ranging from 540, 542 and 584.
              If memory serves me right.
              Didn't put them here originally cause they asked for Jam codes and not error codes.
              IKE
              • Simons
                • Jun 2008
                • 490
                #22
                hahahahhaa let us know what version the PCB is in the S1 . Did you check good the wire harness on back of finisher for rubbing holes into the wires ?
