Hello Everybody,
I face paper jam problem in IR 1600 using bypass try when i use free size paper 345mmX215mm,the paper is jam on fixing unit some time cross middle of paper or just before deliver with paper curl sound.I like to confirm besides free size paper 345mmX215mm all other size like A4,A4R,A3,B4 paper going on bypass very freely & continuously with out any error or paper jam & also using this size paper in pickup unit the output paper is OK.For do the remedy I clean bypass charging roller,still the problem is fix.Can any body fix the problem?
Thanks& Regard
Guna.
Thanks& Regard
Guna.
