ir 2870
  • sundeep202
    • Oct 2010
    • 26
    [Error Code] ir 2870
    there is a error code E000225-0001
    what it means and what should be done?
  • Alex ahir
    • May 2012
    • 125
    Re: ir 2870
    Related to scanner. check scanner cable
      • 16083
      Re: ir 2870
      Make sure the platen glass has the red arrow in the rear left corner of the machine top plate. As indicated in the picture below, the red arrow should be right above the CIS ribbon cable when the glass is installed correctly.
      • sundeep202
        • Oct 2010
        • 26
        Canon ir 2870 error code 000024-0001
        Shows Error code 000024-0001 frequently. I have cleaned the dp unit but still it occurs after one or two copy.
        Suggest plz
          Re: Canon ir 2870 error code 000024-0001
          Suggest plz
          not the doc feeder... the scanner below the glass! look in your manual for disassembly instructs and adjustments
            • 16083
            Suggest plz
            E024 = developing assembly connector disconnection
            Look at the inside surface of the developer where the toner sensor is mounted while rotating the developer cylinder in the correct direction.
            There is a Mylar scraper sheet that needs to touch the inside surface of the developer wall.
            In the image below the inside surface of the developer wall is being touched by the Mylar scraper blade.
            If the blade is damaged or broken off the toner will not be cleaned off of the sensor and give the error code E024.
            If the blade is the problem the developer will need to be replaced.
