ir 2318
  • pulkit jain
    • Dec 2012
    • 73
    ir 2318
    in ir 2318 machine shows an error of "LOAD PLAIN A4 SIZE PAPER"
    i had -
    1.clean the clutches
    2.change the rubber rolle
    3.paper quality is all right
    4.checkout most of the parts
    now i have doubt that this can be happen because of fault in the fixing unit (because the paper jam in the fixing unit, and sometimes it jams in the drawer)
  • teckat
    • 16083
    Re: ir 2318
    i had -
    at what point does that message show on panel
    • pulkit jain
      • Dec 2012
      • 73
      Re: ir 2318
      it shows when paper jam in fixing unit and also when it pass out from fixing unit
      • teckat
        • 16083
        Re: ir 2318
        what paper size is selected
        what location is paper selected from
        is this message to load A4 show when u print from other sizes ?
        is this from glass copies and network print selections
        be more specific
        • Rachid.Akli
          • Oct 2011
          • 595
          Re: ir 2318
          i had -
          Replace the registration clitch.
          Rachid
          "Find a job you love and you’ll never have to work a day in your life." Nagy's father
          • pulkit jain
            • Dec 2012
            • 73
            Re: ir 2318
            be more specific
            what paper size is selected - A4
            what location is paper selected from - both drawer and stack bypass
            is this message to load A4 show when u print from other sizes ? No, but it shows to load correct paper size which is used at that time
            like if I use A3 and if jams than it shows to load correct paper A3
            is this from glass copies and network print selections - both from copy and print
            • pulkit jain
              • Dec 2012
              • 73
              Re: ir 2318
              Rachid
              i think that your answer is quite good
              i had change the registration clutch but i works for few copies or prints
              one more question
              this problem can occurs because of fixing unit
              • DAG COPIERS & COMPUTERS
                • Oct 2010
                • 860
                Re: ir 2318
                '' Is this message to load A4 show when u print from other sizes? NO!''
                Teckat's lead is good; It has something to do with paper size settings, do this: Place A4 size papers in the cassette, After selecting the correct paper size as demanded by the machine, power cycle the machine to allow the settings to take effect. I had a similar problem with an iR2018, tossed me up and down for seveal minutes till I 'accidentally' switched the machine off then on, after selecting paper size. Then when I tried the message had disappeared and it worked. I can't explain why it happened that way, but it worked. Yours may be similar or different.
                • teckat
                  • 16083
                  Re: ir 2318
                  one more question
                  Remove> reseat the Dimms and Connectors on the Main Controller.
