E00075
  • steve schofield
    • May 2010
    • 117
    E00075
    Hi all ...has anyone seen a solid fix fix for e0075 on image runner advance 50xx...i have fitted mod kit and new belt blade ..update firmware on some machines works fine on others they last a week or so then come back out...i have tried leveling machines from castors but still no joy..
  • Setright
    FSS / SPM
    • Nov 2008
    • 247
    Re: E00075
    Well, we had one machine that had not been handled with care during deliverey, and it turned out the entire chassiss was skewed.
    Is your machine still square from all angles?
    • steve schofield
      • May 2010
      • 117
      Re: E00075
      Hi thanks for reply...yes all square problem is its not just 1 machine..i can fit a belt and not here from machine for months then do the same on another and it last a week!!
      • IkeW0491
        • Oct 2013
        • 172
        Re: E00075
        Hey Steve,
        Not sure it this will help or not,
        I had a IR Advance C5250 that was giving E0075 code and the belt was off a little bit.
        The issue I had was that there was excess toner build up on and around belt causing it to be skewed a little.
        Vacuumed machine out well, ensured there was a new clean Toner waste bottle, removed cleaner blade and ensured it was functioning correctly and cleaned it out also.
        Like I said this might not be your issue, but it is worth a try to check it out.
        Hope it helps.
        IKE
        • teckat
          • 16083
          Re: E00075
          sub-code ?????
          e075-xxxx
          Service Mode COPIER>DISPLAY>MISC. Check to see if the ITB-POS and ITB-POS2 values are between -350 and 350. If the values are out of this range, perform the ITB Motor Support Plate Adjustment
          • canonbundy
            • Jun 2012
            • 607
            Re: E00075
            Levelling the machine & replacing parts is BS.
            This has always worked for me (after going through the same as you).
            Behind the ITB motor there is a silver bracket with two silver screws. This bracket affects the tracking of the belt. Remove the ITB motor. Loosen the two screws on the bracket and adjust the bracket 1mm at a time until the belt stops tracking off.
            Run the ITBINIT in SRV Mode & check in DISPLAY MODE for Belt tracking closer to '0' - it will never get even close to this number because it too is BS. as there is no Initialization to '0' as such, but perform the above several times (before readjusting) until the belt movement stabalises around a constant number range - eg. 125 - 169 - 146 - 152 etc. Also visually check with the R/H door open for even distance of the Belt on the Roller both ends.
            • northernlife
              • Sep 2011
              • 847
              Re: E00075
              Other than a chewed shaft on the transfer roller the levelling and the standoffs have worked great for me. Loosen them right up, give the machine a little push to flex it a bit and then perform itb-init until I get within 100 to -100. But again 4 sensors aren't going to give an exact reading so I agree with your calling BS
              • steve schofield
                • May 2010
                • 117
                Re: E00075
                Thanks for Top advice!!! All becomes clear youve saved me much headace!!
                • northernlife
                  • Sep 2011
                  • 847
                  Re: E00075
                  You've checked out the bulletins that our saviour teckat has posted on this machine I hope. They are extremely valuable to carry with you when you do these calls.
                  • MAS15
                    • Dec 2016
                    • 1
                    Re: E00075
                    I pulled the motor, can't figure which bracket you are referring to - I am assuming it's not the one on top of the assembly that is part of the frame connecting the cleaning assembly. Does it actually have adjustment markings and I'm just missing it? ......
                    • luis1984bol
                      • Nov 2011
                      • 155
                      Re: E00075
                      I have had this problem before and I had adjusted this part E075 adjust small.jpg
                      This is located on the left side of the machine. You have to remove the covers.
                      Try to do this adjustment.
                        Re: E00075
                        this thread is over 3 years old...start a new thread of your own
                        • dan7777
                          • Dec 2012
                          • 680
                          Re: E00075
                          Behind the motor that drives the belt are two large screws with red paint (do not adjust color). Bracket up goes more negative. One is harder to see than the other but both the same size.
