Hi all,
Having a problem with a Canon V1 finisher spitting paper everywhere, not pulling it back in.
Now, the finisher in question threw up an E551 error code which we found and sorted.
The problem we're facing is the two plastic flappers that spin around on the shaft, (connected by a black clip that is screwed in) doesn't spin. The only way that this will spin is when the mouth is held open - which then causes a problem of the rollers that are on the mouth cannot push the paper out.
If i do not touch the mouth the finisher will not pull paper back and cause the machine to jam.
So far we have changed ALL boards in the back of the machine and also the mouth assembly.
I'll include a video so you can see the machine working with the mouth held open.
Hope someone can help.
