falah taan
  • falah taan
    • Feb 2013
    • 67
    falah taan
    in my canon ir c2880 there is to port usb one of them to cncte with computer and the second for flash memory .when i put flash memory nothing apper in screen of the massien woh can iuse the second port pleas hepe me
  • northernlife
    • Sep 2011
    • 847
    Re: falah taan
    2880/3380's usb's are only used for printing and flashing software, not storing files on usb media unfortunately.
    • teckat
      • 16083
      Re: falah taan
      The imageRUNNER-iR Series models support USB 2.0 High Speed printing via one USB 2.0 port located on the machine's main controller board. This USB port will look like this:
      This is the only USB port on the machine that will support USB Printing.
      Do not attempt to print using a USB Port on the machine that looks like this below:
      In order to print via the USB port, the following items are required:
      1. The appropriate Canon Printer Kit must be installed in the imageRUNNER.
      2. The imageRUNNER-iR Series models do not ship with a USB cable. A USB 2.0 High Speed cable must be obtained on your own.
      3. Make sure the 'Use USB Device' setting on the iR is turned 'On'.
      Enabling the 'Use USB Device' setting on the machine:
      I. For most imageRUNNERs follow these instructions:
      1. On the iR, press Additional Functions.
      2. Press System Settings.
      3. Press Network Settings.
      4. Scroll down to 'USB Settings'. Press USB Settings.
      5. Select the 'Use USB Device' option.
      6. Set it to 'On'. Hit OK.
      7. Reboot the imageRUNNER for the changes to take effect.
      II. To Enable the 'USB Device' setting on the imageRUNNER 2020/2016 Series:
      1. On the Control Panel, press Additional Functions.
      2. Scroll to and select 'System Settings'. Press OK.
      3. Scroll to and select 'Use Device USB'. Set to 'On'.
      4. Reboot the imageRUNNER for the changes to take effect.
      NOTE: This 'USB Device' setting is only for printing via the USB port on the main controller board. This USB port does not support External USB Devices (mouse, keyboard, etc), the Remote User Interface (RUI), Network ScanGear, or Universal Send functions.
      Other USB Ports:
      Some imageRUNNER-iR Series models have optional expansion boards available that provide additional USB ports. These USB ports look like this:
      In order to connect an External USB Device (mouse, keyboard, etc) to these USB ports, make sure to enable the 'Use USB Host' setting on the machine. When this is set to 'Off', the connection is disabled preventing the use of an External USB Device. See your specific imageRUNNER model's documentation for specifications on what External USB Devices are supported.
      These USB ports CANNOT be used for printing. Use the USB port on the main controller board for USB printing (as described above).
