dear all , i have a canon ir 9070 and its french language can any one send me the system software for it to change the language i searched at the common setting to check if another language available but there's nothing only french can you please .
canon ir9070 english language
Re: canon ir9070 english language
Try an MMI clear (this will reset all the common settings).
Rachid."Find a job you love and you’ll never have to work a day in your life." Nagy's father -
Distinguished road makes you jewel in roughComment
it just was never registered / u should have the SST & 9070 firmware on laptop
Just open SST > Locate Model >Locate Language needed >Register it>then install it
EXAMPLE location below
C:\Canon File Folder\SST System Software Folder\SST Files\iR9070_v17.03\iR105Plus_iR9070\Language
u should also use the same selection register for RUI**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
I always thought that the english language is registered within the system firmware itself.
Rachid."Find a job you love and you’ll never have to work a day in your life." Nagy's fatherComment
