I`ve already replaced magenta cartridge for a new one. Nothing changed. I attache a sample of the faulty image.
iRC1021i magenta background
Re: iRC1021i magenta background
Magenta background over the entire page.
The problem may be caused by a missing connection to the HVT PCB.
On this machine the drum unit has 2 contact points that receive charges on the left side. There is small square silver contact and a rectangular copper contact. They are visible in the image below. If there is no connection with the copper contact the unit will give a light background over the entire page including the blank area.
The background will be the color of the drum that is missing the connection.
The two drum contacts come in contact with spring loaded contact wires in the machine. They are visible in the image below. To check them, turn off the machine and unplug it, next check if the wire contacts are spring loaded and make sure they are not bent or deformed. Compare them with another set in the machine.
The back side of the spring pins in the image above in turn contact the HVT PCB.
The coiled springs on the image below make contact with the HVT PCB.
In this case the lower left spring was knocked out of place by a technician when he reinstalled the HVT PCB.
The spring was in place and visible on the inside of the machine but yet was not making contact with the contact point on the HVT PCB. The tech rechecked the previous techs work and found the coil spring not in it's correct position. The problem was resolved by simply reinstalling the contact spring into the correct position and then carefully reinstalling the HVT. Trouble shooting was difficult because the contact spring was visible and in place on the inside of the machine but not in the correct position under the HVT PCB.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
to add
Prints and Copies have a Magenta Background
This issue can occur if the Bias Spring for the Magenta Cartridge has fallen out of place. Check the Bias Springs and make sure that they are seated correctly.
Are u using a OEM PRODUCT for Toner Supply**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
looks like a BIAS issue/ there is a contact point issue I believe
have u tried another Magenta Drum Cartridge ??
did this issue appear before drum change
has Software for the machine been re-flashed / upgraded to the latest version.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
