Push in fixing unit message
  • charm5496
    • 2387
    I am getting this message on two brand new units (not rebuilds)
    Third new unit is working fine and so is the original unit. Anyone ever run across this?
    I have a feeling there is a lose connector in the assembly somewhere, but I have not across any documentation on this problem so far.
  • teckat
    • 16083
    Re: Push in fixing unit message
    What Model Printer
    • charm5496
      • 2387
      duh...IRC-5185 and I just ran into another one on an IRC-4580....different fixing assembly.
      old ones read fine and a different new one reads fine as well.
      • northernlife
        • Sep 2011
        • 847
        you getting an e012 at all?
        • teckat
          • 16083
          check for a damaged/ front and rear cast metal door hooks. They may be slightly bent preventing the door from latching correctly.
          if damaged >unit will miss-connect (to fixing internal drawer connector) & not sit correct / believe u can swap the left to right
          door hooks (FC6-8851-000)
          when damaged>it sometimes looks closed> but it will actually drop a little to cause message
          Friend reminded me on another issue>> a bent rail
          there is a Canon pub on this/ will look for it----------------
          It is possible that if the fixing/feeder unit is left open for an extended period it can bend the unit and therefore cause the assembly not to properly close when pushed in to the machine.
          Rail Front = FL2-4244-000
          Rail Rear = FL2-4243-000
          • its_just_a_copier
            • May 2011
            • 132
            I've noticed those big screws that hold the hooks loosen up over time.
