problem at 3 way unit ir 3035
  • ramez ghaly
    i have a big problem at canon copier model (ir3035-ir3570-..........)
    problem at 3 way unit (the end of A3 paper)
  • THUK
    • Jul 2008
    • 195
    Re: problem at 3 way unit ir 3035
    Hi what is the problem, can you explain in detail.
    • ramez ghaly
      the proplem in the end of A3 paper out of machine.
      A3 only.
      • teckat
        • 16083
        A3 only.
        Jam Code ??
        Duplex issue in 3 way unit
        • canonbundy
          • Jun 2012
          • 607
          Maybe remove 3-way unit & check sensor flag is locked in properly & sensor clean etc.
