Canon iR2230 Network printer Firmware
  • doko
    • Jun 2025
    [Misc] Canon iR2230 Network printer Firmware
    Hello ...
    I am new to the copiers world .. Recently i bought a canon iR2230 with network card interface and there is network settings in the setup menu .. So i could assign an ip address and netmask and gateway and i connected it to my PC with rj45 cable .. I was able to ping the printer address from the PC but i couldn't print or discover the copier and after some reading here on the forum i was able to access the service mode and i realized that my rom version was "8.33 C" and i checked that there ia no HDD and my Ram was 256 .. My question is how can i upgrade this copier to enable network printing and if anyone from the respectrd members can support me with the Printing Firmware and the instructions of the upgrading process i will be so grateful .
    Thanks in advance
    • 37418
    Re: Canon iR2230 Network printer Firmware
    You have a basic model. You will need a print option kit to add printing.
      • 16083
      Originally posted by doko
      Hello ...
      Thanks in advance
      READ----------
      iR2230 Series Brochure.pdf
      Printing (optional)
      You can upgrade this machine to a high-speed network printer by installing the optional UFR II Printer Kit. This kit incorporates UFR II (Ultra Fast Rendering II) Technology, which utilizes a newly
      invented printing algorithm to minimize file processing and achieve maximum performance.
      * The optional UFR II Printer Kit is also required
      for other options----
      -Remote User Interface
      -Faxing + UFR II Printer Kit and Super G3 Fax Board
      -Mail Box Function
      -Network Scanning-UFR II Printer Kit must be installed
      on your machine, and Network ScanGear
      • doko
        Thanks for replying but i am kinda newbie in this filed .. So i wanted to know what equipment shall i plug exactly and how to get it .. And i also wonder because i have an ethernet card that is working and the printer can ping my PC and vice versa so in my case what is the benefit of this network card if i can't ptint through it ?!
        Thanks again and sorry for asking a lot of questions
        • doko
          Originally posted by teckat
          READ----------
          [ATTACH]22673[/ATTACH]
          Printing (optional)
          -Mail Box Function
          Sorry i didn't see your reply .. I got what u said but i would like to know where to buy this kit and how much does it cost .. Btw i have a 256 ram installed and i have the HDD kit installed without the HDD itself ..i also have an eprom installed but i don't know what type exactly .. If u want me to upload a pic for my machine's board i can do that .
          Thanks for fats replying and for helping newbies
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5007
            READ----------
            Printing (optional)
            -Mail Box Function
            • doko
              High speed? With this piece of c..[ATTACH=CONFIG]22674[/ATTACH]
              Sorry but i don't get this
              • JustManuals
                • Jan 2006
                • 9838
                ​Call a Canon certified technician. You're out of your league here.
                • DAG COPIERS & COMPUTERS
                  • Oct 2010
                  • 860
                  This series of machines have been around for quite sometime, so for the sake of this particular thread, let me assume that you didn't buy it as brand new...sealed in its original factory pack, but as a used or reconditioned copier. If this be the case, it is reasonable to assume that the previous owner used it as a network printer, having installed all the necessary optional accessories required for that functionality. Later on, due to some reasons [probably data security] he or the tech removed the Hard disk, and replaced the 'N' Rom version (8.33N?), with a 8.33C Rom version, to disable the print function, but enable only the basic copy functions.
                  The optional HDD is originally 20GB, and comes with additional memory of 128MB, to make 256MB. But I can see the 256MB is installed, so you say, and the network card is in as well, and you can ping in both ways.
                  - You may need to reinstall the hard disk, format it and reinstall the firmware and the driver. Since you are new in canon, so you say, I suggest you call a canon trained guy to do it for you. This will save you a lot of unnecessary headache.
                  -But it is possible the machine is also just a ROM based model. In all cases, a trained canon tech will sort it out for you.
