canon ir 1600
  • Saji
    • May 2010
    • 97
    canon ir 1600
    canon ir 1600 was showing waster toner full replace drum, i replaced the drum unit, but it still gives the same message, i did Error clear , still the message keep on coming, wht could be the problem pls help.
  • Canon.Tech
    • Mar 2009
    • 335
    Re: canon ir 1600
    When the drum fills with waste it pushes out a gear at theback & actuates a switch. Check this switch is not stuck in etc.
    • Canon.Tech
      • Mar 2009
      • 335
      Re: canon ir 1600
      When the drum fills with waste it pushes out a gear at the back & actuates a switch. Check this switch is not stuck in etc.
      • Rachid.Akli
        • Oct 2011
        • 595
        Re: canon ir 1600
        Hello,
        Clean or replace the toner sensor PS120.[
        ATTACH]22739[/ATTACH]
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • teckat
          • 16083
          Re: canon ir 1600
          as posted by others -------------here is a pic
          'Waste Toner Full
          sensor actuator, highlighted below, may be stuck in a depressed position or the torsion spring may have come off.
          Waste Toner Case Full Sensor, PS120, is activated by the lever shown below.
