How do I change IP address on c5185 with Fiery Controller?
  • crwoo
    • 76
    Hi, i have a c5185 with a H1 controller and I want to change the IP address. I know how to do it, but my browser blocks it. I tried safari chrome and firefox on mac and chrome and firefox on windows 7.How do I get past that? I enter the IP address and on the last tab there is a configure button, shows popup with error saying com.sun.deploy.net.JARSigningException: Found unsigned entry in resource http://10.1.100.10/configureLogin.jarCan anyone help me?
  • blee
    Technical Trainer
    • 62
    Re: How do I change IP address on c5185 with Fiery Controller?
    That error sounds like a Java error on your computer. Try to update or re-install the Jave or JRE
    • crwoo
      • 76
      I have newest java and OSX mavericks. I also tried windows 7. I was able to change it before, but maybe that was because i had an OLDER version of java. i tried disabling the security setting in the java part if the browser and didn't make a difference.How do you guys do it? maybe my H1 server needs a software update, is that user updatable?Thanks.
      • supertype
        • Sep 2012
        • 31
        I will reply with a Video showing you how to manage the Fiery device from the control panel of the copier in about 10 min
        • crwoo
          • 76
          OK please do, that would be appreciated.
          • supertype
            • Sep 2012
            • 31
            here is the video! had problems with the audio at the end, iphone case made the mic drop out. you should be able to follow through and set your ip address up
              • 16081
              Originally posted by supertype
              here is the video! http://www.youtube.com/watch?v=GwBtnLn_0PII had problems with the audio at the end, iphone case made the mic drop out. you should be able to follow through and set your ip address up
              --------------------;great support
              • crwoo
                • 76
                thanks for the video. mine doesn't come back up after the restart. thats odd because the unit works, i just need to change the IP address...i don't need the H1 server, I just tried to remove it and change the setting in the service mode to 0. I was able to find the printer, but it wouldn't print. is there anything else i have to do? I am scrapping a c3220 with PS could i use a part from there? I UFRII would work for me if thats easier.cool chart teckat, but it needs to continue, i was at the last block last night and it didn't solve the problem. :-P :-P
                  • 16081
                  what do u mean it does not come back ??
                  is that after u finish the Run Setup ?
                  u will need the Color UFR II/PCL Printer Kit (is License Activated) for a high-speed network printer.
                  if u remove the H1 Fiery/ the H1 has a Open I/F PCB installed inside Printer that needs to be removed/
                  There is no N BootROM for these series/models. There is only a C BootROM.
                  In order to print using the UFRII/ PCL Printer Kit-N1 or the PS Option-N1, you should receive a LAN number in the kit and MUST register it online using the License Management System. The key must then be entered on the machine in Additional Functions > System Settings > scroll down > License Registration. Press 'Start' on the License Registration screen and then reboot the copier.
                  To verify the printer kit is installed:
                  1. Press the Counter Check button, then hit 'Device Configuration'. If the printer kit is installed, it will be displayed here (ex. UFRII/PCL Printer Kit).
                  OR
                  2. Check the LCNS-TR setting under Service Mode Level 2 > Copier > Option. The ST-LXUFR and ST-PCL should be set to '1', if the UFRII/PCL Printer Kit-N1 is installed. The ST-PS should be set to '1' only if the PS Option has been installed. If these options are set to '0', it means that the option is not installed.
                  * Remember that the PS Option-N1 requires the UFRII/ PCL Printer Kit-N1 and the iR 512MB Expansion RAM-C1 (bringing total memory on copier to 1.5 GB).
                  In order to print via TCP/IP, make sure the RAW and LPD Settings are turned 'On' under Additional Functions, System Settings, Network Settings, TCP/IP Settings. LPD may be set to 'Off' by default.
                  * Note: The Printer Kit license can be transferred from 1 machine to another, the same way a Universal Send Kit can be transferred. Make sure to have the disable code when calling the TSC to perform the transfer. On the i models (C5180i / C4580i / C4080i), the printer kit is standard and cannot be transferred.
                  • crwoo
                    • 76
                    It doesn't apear that I have the printer kit. might do the transfer though.when i click on the setup it reboots the server and then it stays on the wait a moment (check power source... screen that shows on the video. yours took less than a minute. i waited over an hour.
                    • supertype
                      • Sep 2012
                      • 31
                      yes looks like you need more kits for it to sync up with your copier. follow the above posts :/
                      • crwoo
                        • 76
                        Hi, thanks for your help everyone. I got it working by manually rebooting the server after entering setup mode. Just unplugged the server's power and plugged it back in and after 2 minutes it showed up.Thanks again for your help.
                        • supertype
                          • Sep 2012
                          • 31
                          to reboot a fiery the safe way without unplugging it
                          1. Turn the copier off Leave the copier off for about 2-10 minutes
                          2. Fiery should see the copier is off and shutdown.
                          3. Turn copier on and fiery will automatically power on if the main power is in on position on fiery.
