Canon Ir 3300. Responding slow
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1247
    Ir 3300. Copier only....no print or scan reacting very slowly. When you try and copy.... It takes about 20 seconds before it starts and then copies and works normally. When you try and enter service mode it hesitates and then let's you in. If you try and print a user list in service mode it accepts the input but then takes about 2 minutes to respond and then prints normally. Hdd? Any comments appreciated.
  • northernlife
    • Sep 2011
    • 847
    Re: Canon Ir 3300. Responding slow
    Other than mmi clears and the like. Slow 2200/3300's are usually indicative of the hard drive failing. You can usually hear the HDD chugging away when you scan/print anything.
    • teckat
      • 16092
      as posted by northernlife
      replace HDD or
      Try formatting the old hard drive and reloading software
      • blazebusiness
        • 1247
        Originally posted by teckat
        -------------------as posted by northernlifereplace HDD orTry formatting the old hard drive and reloading software
        Thanks for the replies...... I'll format the hard drive and replace it if that doesn't do it.
        • northernlife
          • Sep 2011
          • 847
          Had a call this morning on a 3225 being slow, ui very unresponsive. Had to run a copier > function > system > hd-clear and all was well. Might be worthwhile trying first. If you can physically hear the hard drive chugging away chances are it's the HDD.
          • Simons
            • Jun 2008
            • 492
            been there and done that.
            • RHodg57
              • Dec 2013
              • 191
              We have had to replace a lot of hard drives on those series machines.
              • blazebusiness
                • 1247
                We have had to replace a ton of hdd's on this model also. Never saw a hard drive make the machine react slowly before. Normally when hdd fails unit will not boot up and error code 602 occurs. But replacing the hdd did end up fixing the issue.............thanks again for responding & A Very Happy New Year to all.
                • jiongpao
                  • May 2009
                  • 413
                  I got this issue before and it was a 64MB SD Ram problem
