Ir1025
  • copicatt
    • Nov 2008
    • 361
    Ir1025
    Just placed one in a customer office the other day. She says all prints, faxes and reports are printing two sided. Had her go in to add function... Printer settings... And 2 sided is off..... I've never had one do this and not sure where to change it... Anyone? Urgent. Her checks are printing two sided and if course that dont work...i noticed when I test print ted it dis two sided but didn't notice the fax. Thought it was her program... Evidently not.... Help!
  • teckat
    • 16092
    Re: Ir1025
    u need to go into (Copy Settings>Standard Settings) below
    Additional Function>Copy Settings>Standard Settings>Two-Sided, set to "OFF"
    power off/on printer
    to stop two-sided received Faxes
    1) Press (Additional Functions) --> [Communications Settings].
    2) Press [RX Settings] under --> Press [Two-sided Print].
    3) Default is OFF > but check & Select [Off] --> press [OK].
    4) Press [Done] repeatedly until the Send Basic Features screen appears.
    or
    Returning the Device's Common Settings to their Default Values
    Only the Common Settings located under Additional Functions will be effected
    1. Press the 'Additional Functions' button.
    2. Select 'Common Settings'.
    3. Scroll down and select 'Initialize Common Settings'.
    4. Press 'Yes' at the confirmation message.
    or
    If the imageRUNNER is acting like it is in Duplexing Mode by pulling the paper back into the machine. & No image would be on the backside of the paper.
    Selecting Additional Function > Common Settings > OK >( Scroll to ) 11- Paper Feed Switch > OK > Drawer 1 > OK ( select ) Speed Priority > OK.
    • charm5496
      • 2387
      Re: Ir1025
      almost all new print drivers being released are defaulting to 2-sided printing out of the box. You have to go in and set the driver to default to single sided.
      • copicatt
        • Nov 2008
        • 361
        Re: Ir1025
        Thanks for the info:
        I have resolved the printing on two sided. I installed Canon's UFRII Driver from their site on my PC here at the shop. I opened the driver and went to preferences. Guess what...FYI to all....the driver defaults to 2 sided printing. Called the customer and theirs was set that way also. Had her change the preference to 1 sided and it stopped duplexing off course. Driver fault.
        The fax part I will have her check.
        Thanks!
        • copicatt
          • Nov 2008
          • 361
          Re: Ir1025
          Sorry, we must have typed at the same time....EPA thing I guess. Good to know.
