Canon iR1022iF OUT OF TONER problem....
  • jupiii
    • Apr 2012
    • 9
    Hi Everybody!
    I have a problem with iR1022iF where it says OUT OF TONER, CHANGE TONER.
    The customer changed toner but message didn't goes off.
    I've tried to change developing assy and after that message goes off.
    After few hours customer calls that message appeared again.
    Does anyone had the same problem with that?? What can be problem?
    Thanks!!
  • northernlife
    • Sep 2011
    • 847
    Re: Canon iR1022iF OUT OF TONER problem....
    Contact clip fell off probably. See attached PDF.
    Jas
    • jupiii
      • Apr 2012
      • 9
      Thanks for info!
      When I disassemble it I didn't saw that contact clip fell off.
      But I've cleaned once again all contacts and now it's working
      OK.
      Best regards!
      • northernlife
        • Sep 2011
        • 847
        As I say "it just wanted to be hugged". Happens all the time lol. Glad to help.
        • Waeljallad
          I faced this problem many times. And i fixed by cleaning assembly but this time it doesn t work ' i faced this problem after i cleaned the developer unit axe thank u
