We are going to be installing an ir adv C7200 series machine as a printer only version. Does the fact that we can not do a full automatic gradation adjust cause any issues?
Canon ir advance printer only versions
Re: Canon ir advance printer only versions
If you are printing office colour, maybe not.
If you are doing graphics most likely at some time you will have copy quality issues.
Older printer only models, had an autograd kit available .
Check availability for this model -
Thank you. What does the auto grad kit comprise of?Comment
for Printer Only models
use Color Calibration Utility CC-100
CC-100 Install/Use INSTRUCTIONS
http://software.canon-europe.com/software/0041583.asp?model=
Utility Link**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
