canon 5570
  • satish.ambiger
    • Aug 2012
    • 24
    [Misc] canon 5570
    HELLO
    my self satish I have canon ir 5570. I have problem with my machine while printing. during printing first copy come as normal but printing second copy machine delay printing and it display WAIT ( it takes 50 seconds to print second copy) please suggest me solutions
    Thanks in advance
  • mender
    • Aug 2012
    • 16
    Re: canon 5570
    Is this just when printing pdf's. What about internal report prints and copies.
    • teckat
      • 16083
      Re: canon 5570
      Originally posted by satish.ambiger
      HELLO
      Thanks in advance
      1-To speed up the copy process go into service mode level 2 and under Option>Body>PO-CNTMD, enter "1". This will make the machine do a simplified potential reading, thus speeding up the copy process . Don't forget to turn machine off and back on after changing settings.
      check in SERVICE MODE>ALARM CODES > note any in a Reply (example code 50010 )
      2-Try and replace the Fixing Main Thermistor (THM1) and Fixing Sub Thermistor (THM2).
      • Canuck
        Tech Specialist
        • 1713
        Re: canon 5570
        Does it have an external finisher...if so then the paper surface sensor actuator assembly could be warped or broken....
