If the IR 3235 is a base model and not the 3235i then you would need the USB Connectivity Kit-A1 AND either the PS Printer Kit-AA1 or the Direct Print Kit-F1 to print from the USB flash drive.
If you already have the IR 3235i version then you will just need the USB Connectivity Kit-A1 option.
If you just need to scan to a USB device and not print, then the USB Connectivity Kit-A1 is all you would need as well.
