conon
  • satish.ambiger
    • Aug 2012
    • 24
    [Misc] conon
    Hello
    I have canon ir3300 and i cleared the machine by below procedure for erorr E007-000
    ERR
    DC-CON
    R-CON
    SERVICE
    JAM-HIST
    ERR-HIST
    E354-CLR
    E355-CLR
    PWD-CLR
    ADRS-BK
    CNT-MCOM
    CNT-DCOM
    MMI
    CARD
    ALARM
    is it correct or not for that please suggest. and will it going cause any problems.
  • Brian8506
    • 1664
    Re: conon
    No. You need to replace the fuser film assembly. Did you run a P print? You're gonna have to input the adj and other specs with all that cleared.
    • satish.ambiger
      • Aug 2012
      • 24
      Re: conon
      what is mean by p print and specs? and how to run p print and input and adj specs
        • 16083
        Re: conon
        Originally posted by satish.ambiger
        Hello
        ERR
        DC-CON
        R-CON
        SERVICE
        JAM-HIST
        ERR-HIST
        E354-CLR
        E355-CLR
        PWD-CLR
        ADRS-BK
        CNT-MCOM
        CNT-DCOM
        MMI
        CARD
        ALARM
        I hope u did not CLEAR ALL THOSE SETTINGS/ without Printing Out a P PRINT==
        Backing Up Service Mode
        At the factory, each machine is adjusted, and its adjustment settings are recorded on the
        service label (inside the service book case behind the front cover).
        If you have cleared the RAM and replaced the PCB, the settings under ADJUST and OPTION
        will all return to the factory settings. Be sure to enter the settings indicated on the service
        label.
        You can/should print out the settings stored in the machine in service mode: before any CLEARING of Anything
        COPIER>FUNCTION>MISC-P>P-PRINT
        . In addition, you can obtain a new service label
        using service mode: COPIER>FUNCTION>MISC-P>LBL-PRINT.
        Get a Service Manual
        u can cause more issues if u don't understand what procedures are needed or used
        information purpose only --------------------------------------
        E007 (fixing film rotation error)
        0000= An error in the rotation of the fixing film is detected.Main cause =The fixing film sensor (PS45) is faulty. / The DC controller PCB is faulty.
        Caution = To clear the error, execute the following in service mode:
        COPIER>FUNCTION>CLEAR>ERR.
        1. Wiring
        Are the wring and the connectors connected securely?
        DC controller PCB (J311) <-> relay connector <-> fixing film sensor
        NO: Connect the wiring and the connectors.
        2. Fixing film sensor
        Check the fixing film rotation signal.When the fixing motor is rotating, is the film rotation detection signal sent by the fixing film sensor to the
        connector J311 of the DC controller PCB?
        Film rotation detection signal: 5V pulse signal between J311-A9 (FILM_ROT_D) and J311-A8 (GND); at intervals of 100 msec ON and 440
        msec OFF.
        NO: If the fixing film is normal, replace the sensor.
        3. Fixing film unit, DC controller PCB
        Is there a fault in the fixing film edge rotation detection mechanism
        YES: Replace the fixing film unit.
        NO: Replace the DC controller PCB.
