Canon iR 3220 Print Colors Much Darker
  • cfarris
    • 20
    I am printing from a Mac to the Canon iR 3220 and the colors are MUCH darker and somewhat different than what I see on the screen. Copies come out fine, it's just the prints from the computer that are off. Any ideas?
  • its_just_a_copier
    • May 2011
    • 132
    Re: Canon iR 3220 Print Colors Much Darker
    Does your machine have a ImagePASS?
    If so has it been calibrated?
    • cfarris
      • 20
      No it does not have an imagepass
      • its_just_a_copier
        • May 2011
        • 132
        Are you using a Postscript or PCL driver?
        Either way look to update the driver from Canon's site www.canonusa.com.
        • teckat
          • 16083
          to add on
          PCL DRIVER
          Selecting an objective in the [Quality] sheet automatically sets the color or grayscale settings to suit the document that is to be printed. You can also set the desired color or grayscale settings manually.
          Color and Grayscale Settings
          In the [Quality] sheet, selecting either [Color] or [Black and White] from [Color Mode] sets the desired color or grayscale settings for printing documents.
          To make the detailed color or grayscale settings, you can use the [Color Settings] or [Grayscale Settings] dialog box, containing the [Color Adjustment] or [Grayscale Adjustment], and [Matching] sheets.
          The [Color Adjustment] or [Grayscale Adjustment] sheet enables you to specify the color intensity (for color printers), brightness, and contrast settings affecting a printed document. Use the grid on the right part of the sheet to make an adjustment. A default original image and an adjusted preview image are displayed on the left part of the sheet. Use them to check the result of the adjustment.
          The [Matching] sheet enables you to specify the method of color matching or monitor profile when printing color documents.
          have u done any CALIBRATIONS on Printer ??
          Auto Gradation Adjustment
          Full Adjustment: 1. Press the Additional Functions button.
          2.Select Adjustment/Cleaning.
          3.Choose Auto Gradation Adjustment.
          4.Select the paper type for the gradation adjustment.
          5. Hit Full Adjust.
          6.Press Test Print 1 (the message 'Printing' appears and Test Print 1 is printed out).
          7.Place the first test print on the platen glass. It should be placed face down on the platen glass, with the black bands along the top left edge of the platen glass by the arrow.
          8.Press Start Scan (the message 'Scanning' appears).
          9.Remove the first test print from the platen glass and press Test Print 2.
          10.Place the second test print on the platen glass.
          11.Press Start Scan.
          12. Remove the second test print from the platen glass and press Test Print 3.
          13.Place the third test print on the platen glass.
          14. Press Start Scan. When scanning is complete, the gradation adjustment begins. The message 'Adjusting' appears.
          * Note - When the machine is finished adjusting the gradation settings, the message 'Full Adjustment Complete' appears for two seconds.
          15. Remove the third test print from the platen glass and press Done.
