Quick help iR105
  • V-P
    • Apr 2011
    • 679
    Quick help iR105
    As stupid as it may seem...
    I cannot find in Service Mode where to deactivate the finisher on an old iR105.
    It is supposed to be under COPIER > OPTION > ACCPST-D like in iR7105, but it is not.
    Ideas ?
    • 16083
    Re: Quick help iR105
    Ideas ?
    COPIER>DISPLAY>ACC-STS
    • Rachid.Akli
      • Oct 2011
      • 595
      When installing the IR7105, we used to enter the position of the different accessory options via COPIER > OPTION > ACCPST-D. It was not the case with the IR105. We were just installing the options without any other configuration in the machine side service mode.
      What is your issue ?
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • V-P
        • Apr 2011
        • 679
        Maybe I wasn't clear
        I want to cut off the finisher from the machine and insert the "0" value somewhere in the service mode to tell the machine that there is no finisher attached.
        I cannot find where is it... that is the problem...
        • V-P
          • Apr 2011
          • 679
          Rachid.
          I was not at the customer myself - but he told me that when he unplugged the finisher - some error came up. So I guess smth must be changed in service mode.
            • 16083
            K3/K4
            switch PCB
            SW971: enable/disables the unit.
