E0075 0003
  • Nobilis
    [Error Code] E0075 0003
    Greeting,
    I am not a trained tech on the Canon C5051 but we have one on which we frequently get an E0075 0003 error. From the error code, it is my understanding that the transfer belt is walking to it's full displacement and then sending a E0075 0003 error and the machine stopped, thereby avoiding damaging the belt. After the belt is manually "walked" back into postion, all is well for a little while and then it occurs again.
    I had a tech in the past tell me that this can occur if the machine is not on the level. So, my questions are 1) is this correct 2) does the machine have a built in method in which a tech can adjust the machine to level, or does one have to have a physical level and adjust the feet.
    Since I am not a tech, I cannot get any information out of Canon and we are midstream changing to a new service people so our old tech is gone. I really want to know if I should keep barking at them about checking the level on the machine, or if I am totally out of line to suggest that they adjust it. Thanks for your insight.
  • Ron314
    • Apr 2013
    • 97
    Re: E0075 0003
    I'm not familiar with that particular problem but I do know that as a rule all copiers should be fairly close to level. A very effective and yet simple way to test this is to put a steel bearing in the middle of the copy glass surface, this is the place where you lay a piece of paper that will be copied. If the bearing stays where you've placed it, then the copier is level. I've used glass marbles as well, but they will not be as precise as a single steel ball bearing, none the less for this test it's probably fine.
    Ron
    • teckat
      • 16083
      Re: E0075 0003
      December 1, 2011
      Product : imageRUNNER ADVANCE C5030 / C5035 / C5045 / C5051
      Title : E075 - 0003
      Problem : The machine displayed an error code of E075 with a sub code of 0003. This indicates an error in full displacement of the ITB to the rear side.
      Solution : Behind the ITB motor there is a silver bracket with two silver screws. This bracket affects the tracking of the belt. Remove the ITB motor. Loosen the two screws on the bracket and adjust the bracket 1mm at a time until the belt stops tracking off. The location of the bracket and the screws are shown below.
      Canon USA, Inc. Engineering Services & Solutions Division
      • teckat
        • 16083
        Re: E0075 0003
        August 24, 2010
        Title : E075 error code on the imageRUNNER ADVANCE C5051 Series
        Problem : E075 error code on the imageRUNNER ADVANCE C5051 Series
        Solution : The E075 error code refers to the ITB belt shifting front to rear of the machine and can not compensate. There are two causes that will make this happen. a) The machine that is not level b) Uneven thickness of the ITB belt from front to rear.
        To resolve this issue, first observe the ITB Position value of displacement in service mode under Copier > Display > Misc > ITB-POS. The range is between -300 to +450. If the value is very close to the high end or low end, perform the following:
        a) Check to make sure that the machine is level. b) After leveling the machine, run Copier > Function > MISC-P > ITB-INT in service mode c) Check Copier > Display > MISC > ITB-POS again to make sure the value is approximately within the mid range d) If the value in step c is not within mid range, remove the ITB belt and reverse it from front to rear and repeat the prior steps again.
        • teckat
          • 16083
          Re: E0075 0003
          May 04, 2011
          Title : E075-0000 Error Code
          Error : E075-0000 Error Code
          Workaround : If you have a E075-0000 code, check the Secondary Inner Roller (FC8-4402-000) and the Secondary Transfer bushing Holder (FL3-1109-000). Check to see if the roller shaft ends are worn down. This could be either on the front or rear side. If the shaft or bushing holders are worn, this could cause the belt to shift either towards the front or back of the ITB assembly causing a E075 error code.
          • Nobilis
            Re: E0075 0003
            Ron
            Ron, I ran your test with a glass ball that I had on hand and it accelerated forward off the machine. I relayed this to the repair techs to ask that they make sure to level the machine for us in such a way that we won't inadvertently shift it.
            • Nobilis
              Re: E0075 0003
              Originally posted by teckat
              August 24, 2010
              Thanks for the information Teckat. I looked at the codes and the machine was within the displacement range. So, I decided to relay to the Techs about the machine not being on the level and trust that they will take that into account when they come out to service the unit. I appreciate the pointers from everyone on this so I can speak a bit more intelligently with our reps.
              • teckat
                • 16083
                Re: E0075 0003
                your welcome there are installation procedures that need to be followed on all Canon Printers, sadly not all techs are trained on the products they service----
                the Function below is in the install procedure check for IRADC5051
                COPIER > FUNCTION > MISC-P ITB-INIT
                Initial adjustment of ITB Steering
                Level.1 =Details To make initial adjustment of reference position for the ITB Steering at initial installation or replacement of the ITB-related service parts.
                Use cases - -At installation
                -When replacing the ITB-related service parts
                Adj/set/operate method = Select the item, and then press OK key.
                Caution = Be sure to close all covers before execution.
                Display/adj/set range In processing: ACTIVE, At normal termination: OK, At abnormal termination: NG
                Required time Approx. 1 minute
                Related service mode/
                COPIER> DISPLAY> MISC> ITB-POS
                Display of ITB steering reference position
                Level.1 Details To display the steering reference position of ITB.
                Use case = At initial installation (after execution of COPIER> FUNCTION>MISC-P> ITB-INIT)
                Adj/set/operate method = N/A (display only)
                Display/adj/set range -580 to 580
                Unit = 1 pulse
                Appropriate target value -300 to 450
                Related service mode COPIER> FUNCTION> MISC-P> ITB-INIT
                see attached pdf
                • julka123
                  • Oct 2009
                  • 37
                  Re: E0075 0003
                  [QUOTE=teckat;393590]--------------------------
                  Unit = 1 pulse
                  see attached pdf
                  Hi
                  my problem
                  iRAC5235i changed ITB unit for new one ,after ITB init received E 075-003.Counter 102:25000.
                  any idea?
                  • teckat
                    • 16083
                    Re: E0075 0003
                    Is printer level ?
                    What is reading on display ?
                    • julka123
                      • Oct 2009
                      • 37
                      Re: E0075 0003
                      Is printer level ?
                      Printer is leveled,reading misc ITB 580,ITB unit is new one .E075-003
                      • masky
                        • Aug 2010
                        • 49
                        Re: E0075 0003
                        December 1, 2011
                        Title : E075 - 0003
                        hi
                        hello
                        you can see this newsletter somewhere?, would need to see The location of the bracket and the screws are shown below, do not know the location of the talk
                        please upload the newsletter to see
                        • julka123
                          • Oct 2009
                          • 37
                          Re: E0075 0003
                          Originally posted by masky
                          hi
                          hello
                          Please no problem
                          • Canuck
                            Tech Specialist
                            • 1713
                            Re: E0075 0003
                            Canon has 8 million bulletins on this issue. Install the latest mods. Done a few...works ok.
                            • northernlife
                              • Sep 2011
                              • 847
                              Re: E0075 0003
                              The bearing on the transfer roller on the ITB itself (black roller that presses against the secondary transfer roller on the right door) will slip and start chewing out the shaft. Machine should be leveled as per the installation instructions. You should be doing the itb-init at install. Teckat posted the bulletin that we got from Canon explaining the e075 ecode in detail in a previous post. Once the machine is level and the bearing/shaft are ok you'll never see that code again. But that is what I'm seeing on my turf, you rmileage may vary.
