I get this error on start up E000004-0103. What is this error all about and what can I do to fix it?
Thank you for the help!
E004 0103 = The IH current is faulty. (no current)
E004 =The IH power supply is faulty/the IH control mechanism is faulty.
After correcting the fault, be sure to reset the error.
(COPIER>FUNCTION>CLEAR>ERR)
E004 =there is an error in the IH power supply/IH control mechanism.
Remove & Inspect the Fixing Assembly before doing a CLEAR ERR
things that can contribute to E004
1. Re-fit all the connectors of the Fixing Heater Power Supply PCB.
2. Replace the Fixing Heater Supply PCB with a new one.
1-Fixing Heater Power Supply
2-Fuser Heating Element
3-DC CON pcb
4-AC Driver PCB
5-IH Cable Guide unit
