Hello,
I have this machine in wich we are currently using Katun toner's on the 3 color's and oem for bk. I have replaced bk drum unit and the other 3 color's are at ~200% used.
Today i had to print few hundred pages and I had this briliant ideea to use full autogradation for heavy paper (wich I'll be using) and now my colors are very light. I'm looking in SM for autogradation term buc I can't figure how can I revert the setting's or full the machine to go back. I don't work on this model of Canon, I'm only used with Sharp, where i have trained.
I have cleaned atdc sensor's an dev station's but no succes there. Pascal setting's aren't hellping either.
Waiting for advised advice.
Thank you.
Thank you.
