IR5000, part# touch panel please.
  • Hansoon
    • Sep 2007
    • 3390
    Anyone having for me for the IR5000, the part# of the touch panel please?
    Hans
  • teckat
    • 16083
    Re: IR5000, part# touch panel please.
    Hans
    u mean the LCD ???
    FG6-5428-000 / #20 LCD CONTROL PANEL UNIT in pic
    Calibrate Touch Points On The LCD Display
    The calibration is a Service Mode Function. in Service Mode>Function>Panel>TOUCHKEY
    • Use it to match points of presses on the touch panel and the LCD coordinates.
    • Execute this mode if you have replaced the LCD unit.
    Using the Mode:
    1. Select TOUCHKEY and press the OK key.
    2. Press ' + ' indicated on the touch panel at nine locations in sequence. You might need a FINE TIP instrument to assist in this step.
    3. Select TOUCHKEY once again to end the operation.
    Note: There are times when the '+' symbol is off the screen and the adjustment cannot be performed. Additionally, the touch panel may not respond at all and no adjustment can be performed, in either case the defective component will need to be replaced.
    • Hansoon
      • Sep 2007
      • 3390
      No I meant the touch panel, the upper glass pane. Is it not available separate?
      Hans
      • teckat
        • 16083
        Hans
        u mean an external monitor screen
        post a pic
        • Hansoon
          • Sep 2007
          • 3390
          Isn't there on top of the LCD unit a touch panel with this machine? I mean inside the unit marked pos.20. I have no machine at hand but am asking for a customer.
          Hans
          • teckat
            • 16083
            Hans
            there is nothing inside the LCD touch shown as #20 in pic /
            there is the FB4-6704-000 / SHEET, GROUNDING shown as #1
            what exactly is the issue with the control panel LCD
            there is a FACEPLATE (upper control panel cover)available __ see below
            Part Number for the Control Panel faceplate is FB5-3701-000. Below is an illustration with an arrow pointing to the faceplate.
            • wseyller
              • Sep 2012
              • 1129
              I think he means what I call a digitizer. I know its not call that here but it is what detects finger press on the screen. The LCD doesnt do that as it only displays video to our eyes. This touch screen or digitizer lays on top of the lcd. Just like on a smartphone and every other device in the world using touchscreens.
              Unless the touch overlay is permantely attached to the lcd as one part, In the picture posted I'm guessing its item number 1.
              Sent from my DROID BIONIC using Tapatalk
              • teckat
                • 16083
                it,s. # 1 on pic
                • Hansoon
                  • Sep 2007
                  • 3390
                  It looks physically very much as Pos.1 but that's not the part. The part I mean has a 4-wire ribbon cable connected to it. That ribbon cable is likely the right hand one coming out of Pos.20. (J-6507)
                  Obviously Canon does not have a separate part # for it as with their other machines. Example: FK2-0329-000 or FK2-0246-000 for the iR2220, 3300, iRC5800 etc.
                  Hans
                  • Brian8506
                    • 1665
                    Canon doesn't have a part # for that touch panel. Get an LCD from Nationwide. Fairly cheap. 5020 and 6020 have separate number but the LCD is different.
                    • RHodg57
                      • Dec 2013
                      • 191
                      FK2-0329 is what we have used. Analog Screen and it has solved most problems with touch buttons not working.
