Preventative Measure Against 110F Jams--Various Finishers
  • teckat
    • 16083
    [Jamming] Preventative Measure Against 110F Jams--Various Finishers
    110F: Lower Delivery Sensor Stationary Jam
    The paper does not come out from the Lower Delivery Sensor (PS6) [1] within the specified
    time after the Buffer Path 2 Sensor (UN14) detects the paper.
    The Tie-Wrap around the Wire Harness connected to the Operation Feed Motor (M26) in the Feeder Assembly gets caught on the upper side of the Wire Harness Guide. During transportation or normal operation, the Connector (J541 on the Operation Feed Motor can become loosely seated and partially or completely disconnected due to vibration or shock.
    Products Affected: Serial Numbers Affected:
    Finisher-AF1 ---All Serial Numbers
    Saddle Finisher-AF2 ---All Serial Numbers
    Finisher-AJ1 HLT00001 ~ HLT00704
    Saddle Finisher-AJ2 HLX0001 ~ HLX01786
    Finisher-AK1 NWB0001 ~ NWB10068
    Saddle Finisher-AK2 NWF0001 ~ NWF10072
    Booklet Finisher-F1 PRO ---All Serial Numbers
    Staple Finisher-Q1 PRO QXR0001 ~ QXR01252
    Booklet Finisher-Q1 PRO PMV0001 ~ PMV00832
