HELLO seniors and friends, in IR 2530 when we make copies on dadf, display shows MEMMORY FULL . there is no details in servicemanual. what is the solution for it? before in one IR 2520, I faced same problem. that time i replaced main controller pcb. that was ok. if there is any other solution with out replace the main controller. can you please advice best remedy ? on platten glass no problem.
Ir 2530 memory full error
Tags: None -
Re: Ir 2530 memory full error
try a clear all (backup user settings. address book, etc first) if that doesn't work then chances are the usb stick that the unit uses for storage is fried. -
is there a fax on this unit?
if the received faxes are not printing out then they are filling up the memory giving you that message.
Doing a clear all will flush all of those jobs out as well as all of your customers network settings...etc. Be careful before executing this function.Accidents don't just happen. They must be carelessly planned.Comment
check the memory for an e202 if it has that code its probably the document feeder...also the wrong driver can cause this problem, im betting on the feeder, if you have the same machine see if you put the feeder on it if the problem followsComment
There are two remedies to this problem: 1)-Print the already scanned pages, and continue scanning the remaining pages. 2)-Divide the originals into smaller batches and scan them one by one.
This is not a technical fault but a design limitation, I am not sure if there's provision for extension of the machine's memory. There was no need for you to have replaced the main controller of that iR2520 as you did.Comment
