canon scanner dr7090 error code p081
  • 4color
    • Jul 2025
    [Error Code] canon scanner dr7090 error code p081
    Dear friends,
    I have Canon scanner Dr-7090c during morning time probably for 2 to 3 hours paper get jammed and give error code p081.
    but once it start smoothly, rest of the day it works fine.pls help ....i don't have manual or code list for this model so unable to trace further.
    if some one help by sending the code list it will be a gr8 help.
    activity done
    we had replaced feed rollers.
    cleaned all sensors. and paper path roller.
    in tools mode we had sens-int done.
    thanx in adv
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: canon scanner dr7090 error code p081
    Originally posted by 4color
    Dear friends,
    activity done
    thanx in adv
    Hello,
    Have you replaced the separation pad ?
    If there is any feeding roller clutch, replace it.
    Rachid
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • 4color
      Originally posted by Rachid.Akli
      Hello,
      [ATTACH=CONFIG]23379[/ATTACH]
      Rachid
      Thankyou I think this list will help a lot. I'll try replacing the clutch as separation pad was already changed
      regards
      puneet
      • djwhoo
        • Aug 2013
        • 117
        well... what worked?
