Gd morning guys..I have one unit IR7105...every time this machine show error code E069.....how to soft this problem? Anyone can help me??
IR7105
Tags: None
Re: IR7105
what work ? if any were u doing before e069 code
Check your transfer separation corona assembly.
E069 may be caused by a faulty 10K Ohm resisitor located in the Transfer Corona HVT Cable.
An Ohm check of the Transfer Corona HVT cable should result in a 10K +/-5% Ohm value, if over limit value or Ohm value outside of +/-5% is is read by meter then resistor has failed. Replacement of Drum Duct HV Connector Assembly (found in figure 106 of the imageRUNNER 7105 Parts Catalog) resolved the E069 code.
Location of 10K Ohm is shown below.
**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Re: IR7105
The upper fuser Roller is connected to the transfer current too via a cable and a sliding contact at the backside of the fusing unit. Check if they are ok and not shorten out, also check the isolation bushings of the upper fuser roller or you will get an E69 too.If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
Re: IR7105
Replace the transfer corona assembly. It is, probably, arcing.
Rachid."Find a job you love and you’ll never have to work a day in your life." Nagy's fatherComment
