DDR2-SDRAM (M0) 512 MB (standard / Op.*) / clock frequency: 200MHz
Product name: Additional Memory Type B (512MB)
Rasterizing, rendering, resolution conversion, coding / decoding To be used when using the following options: PS Printer Kit-AE1, Direct Print Kit (for PDF / XPS)-H1, imagePASS-B1, ColorPASS-GX300 * The capacity differs according to the location or model
Rachid.
"Find a job you love and youโll never have to work a day in your life." Nagy's father
E613 1536 00 Title Faulty/insufficient image memory (Main Controller PCB2)
Description No necessary memory at Main Controller PCB 2
Remedy Make the Memory capacity at Main Controller PCB 2 as
indicated by 1536.
