Interesting problem......Copier is jamming due to both cassettes feeding paper at the same time. Have'nt seen this problem before on this model and found nothing in the Canon knowlagebase on this issue. Sensors seem to be ok and have been cleaned. Probably main board issue.... Any ideas?
Canon IR 2030i feeding from both cassettes
Last edited by blazebusiness; 01-09-2014, 04:02 PM.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comTags: None -
Re: Canon IR 2030i feeding from both cassettes
There's modded pickup assemblies for these btw. Solved one of my problems.Comment
try DCON CLEAR ??
update or reload [Overwrite All] firmware**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
