Canon IC2220
  • northerntech
    • Jun 2008
    • 69
    Canon IC2220
    Sorry about this one but it is for the customer. Yes they should replace it because it is old..... have two error codes. 1-##280, and ##102. It is notfaxing to an IR 2800, we can fax to the 2800 from our 4050. the IC2220 can fax other machines any suggestions thanks in advance...
  • kwazimoto
    • Jan 2007
    • 199
    the book talks about poor lin condition for both codes.. it says to raise the outlevel in #2 menu parameter 007 so the party's machine can recievie tcf...also adjust NL equalizer in #2 menu parameter #5..also refer to #1 SSSW-SW03 for echo countermeasure.. also it talks about trying it manually just to see if it sends....hope this helps
    • northerntech
      • Jun 2008
      • 69
      Thanks for the info. this was one time i did not jump on it being the phone line and wouldn't you know it Telus is in repiaring my recieving end today thanks and cheers
