ir5055
  • akm
    • Sep 2012
    • 155
    [Error Code] ir5055
    Dear /CopyTechTeam,
    Please i want your help i face a problem with IR5055 that gives ERROR 0000061-001
    after i changed the value of PO-CNT from 1 to 0 the error disappear but the copy has a black background . i changed the wire of primary , adjusted the height of the wires ,check the pretransfer ,transfer assemblies but still has a black ground as appear in the attachment
    thanks
    akm
  • Rachid.Akli
    • Oct 2011
    • 595
    Re: ir5055
    Hello,
    In Service mode > COPIER > DISPLAY > DPOT, reccord and send back the following values:
    VL1T = (light-area potential target value; in V 1)
    VL1M = (light-area potential measurement value; in V 1)
    VL2M = ( light-area potential measurement value for developing bias; in V 1)
    VDT = (dark-area potential target value; in V)
    Rachid.
    "Find a job you love and you’ll never have to work a day in your life." Nagy's father
    • akm
      • Sep 2012
      • 155
      Re: ir5055
      Originally posted by Rachid.Akli
      Hello,
      Rachid.
      thanks Rachid.Akli i will visit the m/c record and send back the reading
      akm
      • teckat
        • 16092
        Re: ir5055
        Originally posted by akm
        Dear /CopyTechTeam,
        [ATTACH=CONFIG]23570[/ATTACH][ATTACH=CONFIG]23571[/ATTACH]
        thanks
        akm
        so u had a copy with background ?
        then changed PO-CNT from 1 to 0 --and now a black/very dark copy ?
        was that the original problem in first copy shown ????????
        The main power switch must be cycled for the PO-CNT change to be activated.
        Laser Shutter >is activated by the pin on the Primary Fan Duct Assembly.
        The pin actuates the shutter through the opening in the Machine Front Plate
        If an error code of E061 or E100 is experienced, check the shutter operation and the pin on the Primary Fan Duct Assembly.
        If the pin is broken, it should be replaced. The pin can be replaced by replacing the Primary Fan 2 Duct.
        Duct, Primary Fan 2 FC6-3540-000.
        • mramlawi
          • Jul 2011
          • 838
          Re: ir5055
          Dear /CopyTechTeam,
          thanks
          akm
          did u tried to make a report print from the machine ?
          Distinguished road makes you jewel in rough
          • akm
            • Sep 2012
            • 155
            Re: ir5055
            Dear/ Eng. Teckat
            Eng.Rachid.Akli
            Eng.mramlawi
            very thanks for your rapid answers, the readings of PO-CNT are
            VL1T=75V
            VL1M=235V
            VL2M=236V
            VDT=400V
            and i will check the pin of the primary fan installed correctly or not and feed back the result.
            thanks
            akm
            • Rachid.Akli
              • Oct 2011
              • 595
              Re: ir5055
              Hello,
              From the above values, i see that VL1M= 235 Volts. This is too high and it should be around VL1T. The reason is that you have a dirty dust proof glass or a dirty laser. So, start by cleaning them. If the issue is still there, replace your laser.
              In this model, the laser beam dischrges the blank zones.
              Rachid.
              • Canuck
                Tech Specialist
                • 1713
                Re: ir5055
                I have seen the wires break in harness for potential control sensor. Like stated.VLm is too high...laser not discharging drum. Pin for shutter possibly broken as mentioned
                • akm
                  • Sep 2012
                  • 155
                  Re: ir5055
                  Dear / CopyTechTeam
                  I like to inform that the ERROR E 00000061-001 is solved the reason is the pin of the primary duck fan assembly not open the shutter fully and now the m/c IR5065 works good very thanks.
                  akm
                  • teckat
                    • 16092
                    Re: ir5055
                    Dear / CopyTechTeam
                    akm
