hd for iR5075 and iR5570
  • MARDSO
    • Nov 2009
    • 31
    [Error Code] hd for iR5075 and iR5570
    I have a machine that appeared to go 5075 E602! hd is defective or lost system! I have the service tool and firmware, but do not know which model necessary to put in your hd! if anyone knows which models for iR5075 and iR5570 and can pass? thank you very much! : Confuso:
  • micko_gm
    • May 2008
    • 18
    Re: hd for iR5075 and iR5570
    Do you have the old harddisk,usually it's seagate...
    • teckat
      • 16083
      most current hard disk drive part number for the iR5050, 5055, 5065,
      and 5075-----------
      The Current HDD part number is WM2-5231-000===Fujitsu MHV2040AH
      iR5570 (iR5070/iR5570/iR6570)
      WM2-5216-000,
      FK2-4907-000
      =Hitachi HTS541020G9AT00
      • MARDSO
        • Nov 2009
        • 31
        thanks for the reply! I live in Brazil and I'm not finding these hds here! you have to sell? as is? is to send to Brazil?
        • teckat
          • 16083
          find on GOOGLE or AMAZON OR eBAY
          just type or past in search box/ look for refurbs or new if available
          MHV2040AH
          HTS541020G9AT00
          examples below---------
          http://www.amazon.com/Fujitsu-MHV2040AH-40GB-5400RPM-Drive/dp/B000KPW6TS
          http://www.amazon.com/IBM-HTS541020G9AT00-Travelstar-5400rpm-Grade/dp/B003GDT04K
