the machine will be on for sometime and the screen will eventually go off pls help
i change the memory and the hard drive of a working machine still no joy
1-Was this issue > after servicing printer
2-Does the machine still Boot Up
-Check the connection between the Sub-Main Controller (J1303) and the Main Controller (J1209) to see if they are seated correctly.
-U swapped both memory ??
-REMOVE AND CLEAN BOOT ROM> RE-SEAT IT
-Remove & also re-seat the control panel connectors.
-There are many reasons the LCD screen on the C3200 is blank but this senario gives a hint. The Main Controller PCB has an LED101 which is ON during normal operation. When you experience a blank LCD screen, inspect the Main Controller PCB LED101, if the LED is OFF, then replace the SRAM PCB (FG3-3669-000) which is mounted on the Sub Main Controller PCB.
LCD on the control panel is blank, but the greenpower LED is lit.
Ensure that the voltage between the neutral and ground poles is 1/2 a volt or less. If the voltage is higher than 1/2 a volt, an electrician needs to look at and correct the outlet. See the diagram below for check points.
I did all of this Took the main Controller PCB out clean it and re seat the connectors but still no joy
