looks like the fuser is good and the e000-100-0001 resets and runs. They just added toner and these problems started. e000-025 looks like toner bottle motor is not working, I pulled it out and tested using "forced toner add" , the feed motor worked. Also manually fed toner in DV unit, to stop a "toner low" condition. I am mostly a Mita tech so can a good cleaning of the fuser unit take care of the E000-100-00001? I have the copier running for now but Know that it needs more work. I need the part # for the toner bottle motor.
Thanks GAr
Thanks GAr
