IR ADV 7055 Errorcode 197-0100!
  • diguo741
    • Nov 2012
    • 16
    [Error Code] IR ADV 7055 Errorcode 197-0100!
    I have a machine 7055 with the problem e197-0100 .
    The copier is displaying an error code of e197 -0100 ,copier can not use,like picture!
    Help me solve the problem !!Thank you
  • teckat
    • 16083
    Re: IR ADV 7055 Errorcode 197-0100!
    [ATTACH=CONFIG]23606[/ATTACH][ATTACH=CONFIG]23607[/ATTACH]
    Guess u are not a tech by that question ??????
    E197-0100 error code -
    Serial communication error
    serial communication error with the Fixing Feed Driver PCB.
    1. Check the connection between the Fixing Feed Driver PCB (J1550) and the DC Controller Interface PCB
    (J1214).
    2. Replace the DC Controller Interface PCB.
    3. Replace the Fixing Feed Driver PCB
    • Herrmann
      • Jan 2006
      • 792
      Look here, maybe this will help you:
      http://www.copytechnet.com/forums/sh...ht=#post370390
      If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
      • diguo741
        • Nov 2012
        • 16
        (J1214).
        You see the service manual ~ QQ截图20140118220819.jpgQQ截图20140118220921.jpg they say laser interface pcb ~ but i change the laser pcb no use ~ why you service manual say fixing feed ? i do not konw which one is right~ can you tell me ? thanks~
        • diguo741
          • Nov 2012
          • 16
          Thanks for your reply ~ i think they are different problem ~ i do not konw what can i do ~ crazying ~
          • teckat
            • 16083
            You see the service manual ~ [ATTACH=CONFIG]23616[/ATTACH][ATTACH=CONFIG]23617[/ATTACH] they say laser interface pcb ~ but i change the laser pcb no use ~ why you service manual say fixing feed ? i do not konw which one is right~ can you tell me ? thanks~
            0000000000000000000000000000
            sorry about that/ my error/ mixed up that sub-code
            that e197 is a tough code to pinpoint
            in service log do u see any more e197 codes ?? with different sub-codes
            E197 -0100 -05 Title Serial communication error
            Description of detection = Serial communication error in ASIC
            Measures= Laser Interface PCB issue
            1. Check the harness between the Scanner and the Video Board
            2. Replace the Scanner Board
            3. Replace the Video Board
            this may be helpful
            / check it out
            E197-0100 error code would come up at start up. This is an error in communication with the laser interface.
            Tech has replaced the video board and main controller 2 and still has the issue.
            Had tech check for 24V on J5600 pin 1. He would get 24v for a few seconds and then it would drop to 0V. Had tech remove all loads from the laser power supply and still would loose the 24V.
            Workaround :
            In this case replacing the UN7 Relay PCB (FM3-9578-000) resolved the issue.
            imageRUNNER ADVANCE
            C9075 PRO/C9065 PRO/C7065/C7055
            Service Manual
            April 30, 2013
            Revision 9
            • diguo741
              • Nov 2012
              • 16
              this may be helpful
              / check it out
              Workaround :
              imageRUNNER ADVANCE
              Service Manual
              April 30, 2013
              Revision 9
              OK, thanks for your reply ,I think it is a good idear ~ i will try then tell you the reasult ~ anyway thank you very much! you are the best of best tech ~
