i have machine down to the point of 3 screws and cooling fan removed and can't get the assm to roll out of machine.any advice??thanks
help on remove on ir9070 transfer belt
Re: help on remove on ir9070 transfer beltadvance
advance 9070
release the green fuser/transport latch and pull towards you.
remove 1 screw from the left side and 1 from the right of the panel above transport.
remove cover from the middle of that same assembly and remove cover.
you will now see a handle, turn it counter clockwise to release pressure
then pull assembly towards you.
there it is
why do you need to get to the ITB?Comment
