IR2270 feeder only runs 2-sided
  • repeatcopiers
    • Sep 2008
    • 591
    Have an ir2270 that runs every document through as 2-sided in the feeder. If you actually select 2 sided, it runs the original through the feeder 4 times. Customer has had this copier for several years and it just started happening. Any ideas?
    Re: IR2270 feeder only runs 2-sided
    Have you initialized the common and copy settings?
    • repeatcopiers
      • Sep 2008
      • 591
      Yes we have initialized both common and copy settings.
      • Brian8506
        • 1664
        Going on memory here but I believe it's in sm level 2 copier/option/user.Find scn slct and change to either 0
          • 16083
          Brian8506 > U Nailed it on the Head
          Perform the following in Service Mode, to have the Feeder scan the original once for single sided copy.
          Service Mode...LEVEL TWO:
          COPIER > OPTION > BODY > SCANSLCT > set to "0"
          • repeatcopiers
            • Sep 2008
            • 591
            Thanks so much, that worked! Not sure how is got changed, they had the copier for over 2 years before it started happening.
              • 16083
              Tech or a Nosy Key-OP who reads
