Canon C5030
  • tbscopy
    • 11
    [Error Code] Canon C5030
    I have a Canon C5030 that is giving me error message E000045-0000. I need some instruction on how to fix this. A picture of the part in question would be most helpful.
  • northernlife
    • Sep 2011
    • 847
    Re: Canon C5030
    Transparency sensor fault.
    1. Check installation or soil of the Transparency Sensor
    (UN51) and the prism.
    2. Check the Sensor Harness (to see if the harness is
    caught, disconnected or physically removed).
    3. Replace the Transparency Sensor.
    4. Replace the Pickup Feed Driver PCB (UN2).
    • Rachid.Akli
      • Oct 2011
      • 595
      Re: Canon C5030
      Hi,
      This could help I hope.
      Rachid.
      "Find a job you love and you’ll never have to work a day in your life." Nagy's father
      • tbscopy
        • 11
        thanks!
        This really helped out! I played around with the sensor for a bit and it eventually worked. I really appreciate the help and quick response!
        • tbscopy
          • 11
          The picture was also a very big help!
