Canon ir 1730f/fuser /question
  • cucuklotz
    • Mar 2007
    • 611
    HI,
    Customer has Ir 1730F with knocking noise from fuser.ONE GEAR looks very frayed(White gear that drives fuser).Is it easy enough to change fuser gears or am I
    better off replacing fuser unit,I couldn't find rollers separate from unit and service manual didn't have fuser disassemble in it.
    Any help kindly appreciated.
    THANKS ANDY
  • ernesto
    • Oct 2011
    • 430
    is the noise like a train? .....toc..toc..toc
    if the answer is yes, you could adjust the screws that you can see in the picture.they are back the machine.
    http://www.youtube.com/watch?v=0QqmIq_NOE4&feature=youtube_gdata_player
    all the best
    • cucuklotz
      • Mar 2007
      • 611
      Re: Canon ir 1730f/fuser /question
      HI
      Thanks for help.GEAR ON fuser is stripped pretty bad.
      THANKS ANDY
      • IkeW0491
        • Oct 2013
        • 172
        Originally posted by cucuklotz
        HI
        THANKS ANDY
        Hi Cucu,
        If the gear on the fuser is stripped that bad.
        It would be advisable to just replace the fuser, you don' t wanna have to get into disassembling and reassembling a fuser.
        Also I would check the screws that Ernesto told you to, just to make sure they are tight.
        IKE
        • cucuklotz
          • Mar 2007
          • 611
          THANK YOU.I ORDERED FUSER UNIT TODAY AND WILL LOOK AT POSITION OF Screws when I install.
          THANKS ANDY
          • cucuklotz
            • Mar 2007
            • 611
            THANKS,
            Fuser did the trick and I made sure screws were adjusted and aligned.
            ANDY
