Error code on Finisher V1.
  • Jhonjon
    • Sep 2013
    • 208
    [Error Code] Error code on Finisher V1.
    Gentlemen, I need help in Canon 7095 finisher V1 error code E-000551-001. According to Mr. Jim Intravia the power supply fan in the finisher is the cause. I try to inter change the fan from the power supply to the one in the middle of the finisher still intermittent the same error appears. Is it possible that not only the fan is the trouble?!...I'm not a Canon technician and work only in a small shop who dont have any spare parts for testing to isolate the problem...Thanks in advance.
  • vigour
    • Aug 2010
    • 1038
    Re: Error code on Finisher V1.
    The other solution is to replace the finisher controller
    • Jhonjon
      • Sep 2013
      • 208
      I'll try to replace the finisher controller and re-post what will happend...Thanks Mr. Vigour
      • Rachid.Akli
        • Oct 2011
        • 595
        Hello,
        Verify the continuity between the fan and its corresponding connector J103 on the finisher controller PCB.
        Rachid.
        "Find a job you love and youโ€™ll never have to work a day in your life." Nagy's father
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • aco.bk
            • Sep 2012
            • 130
            • Jhonjon
              • Sep 2013
              • 208
              Yesterday the user call that the machine have the same error. Twice i cancell the error because the first try the error re-appear the second one the error dis appear and the machine works. Try to copy a couple of thousand the machine works fine. One thing i've notice the machine error re-appear on the second day, what an odd! I Also try to check the fuses on the board but all are okay. I will try to find a controller board and test it. Will keep you posted what will happend...
              Thanks for the reply...
