ir2020 blank screen after power save
  • incognegro
    • Feb 2013
    • 20
    Hi all.
    I have a Canon that, when left overnight, has a blank screen in the morning. The op panel is lit, so it's getting power but none of the buttons or the touch panel works. The only way to get rid of it is the power the machine off/on. Then it works fine after that.
    Any ideas what this might be?
    I'm a Ricoh tech and I don't have much experience with Canon equipment.
  • canonbundy
    • Jun 2012
    • 607
    Re: ir2020 blank screen after power save
    Originally posted by incognegro
    Hi all.
    That usually means the machine has gone to 'sleep' and will resume normal operation when the 'power' button on the top right of control panel is pressed - the sleep time can be changed by pressing Additional Functions > Timer Settings.
    • incognegro
      • Feb 2013
      • 20
      No the power button doesn't work. The only way to get the machine to work is to switch it off and on.
      • montana
        • Aug 2008
        • 392
        Hi all.
        hi...check the RAM maybe is faulty
