This damn IPF 6100 wide format
  • Acme
    • Jan 2013
    • 155
    couple of questions please regarding "execute printhead cleaning....or replace printhead L" that never goes away message. New P/H. current F/W.
    Do the purge wipers have to be in perfect condition, the front ones have a little wave to them but the actual rubber wipers look good on both sides. Purge caps work fine.
    Air in the lines: now I can see tiny little bubbles in the yellow and magenta lines but it by far are not 1 inch gaps in the tube, more if 1/16" and they move while the cleaning process. if its a sealed system do i just purge all the lines and start fresh?
    I've also re-seated the ribbon cable on the carriage.
    could this really be the main board, jesus they are expensive.
  • northernlife
    • Sep 2011
    • 847
    Re: This damn IPF 6100 wide format
    Check for continuity from one end of the ribbon cable to the other, pin by pin
