Canon irc2030 error e0025-0200
  • copiertech
    • Oct 2010
    • 55
    [Error Code] Canon irc2030 error e0025-0200
    Dear all,
    we are getting the following error after replacing all drum units and need to calibrate it but after calibrating the drum unit, machine gives the error e0025-0200.
    And we need to remove the transfer belt can you please advice how?? We been search in the machine if there is any locks or soft lock could not find any.
    Thanks all of your help
    Waleed
    Copiertech
  • northernlife
    • Sep 2011
    • 847
    Re: Canon irc2030 error e0025-0200
    Open front cover. the left cover is held in with one screw. remove the screw and shift the left side cover forward to release it. Metal clip and 2 connectors and the laser unit comes right out. The laser cleaning wand does a poor job of cleaning the laser. ITB removal is remove all drums, open right door, pull down the metal piece with the 2 optical sensors on it, lift up on the blue handles from the ITB and it should release and slide out.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • copiertech
        • Oct 2010
        • 55
        Thanks Northernlife for your advice,
        I have done all cleaning and checking, but till now i still get the same Error E0025-0200????
        What causing such error and what is the solution?????
        Is there any resetting code for it????
        Thank you for your advice.
        Waleed
        Copiertech
        • canonbundy
          • Jun 2012
          • 607
          Originally posted by copiertech
          Dear all,
          To remove ITB assy - lower R/H Door, press in the 2 'silver' plates on the L & R/H side hinge arms, this drops the R/H door down even further - pull the T/fer unit down & slide/angle up.
          The Error code refers to Cyan Toner hopper - try vacuuming inside the hopper to clear the toner sensor of any buildup - if that doesn't work, might have to replace the Hopper assy - had to replace 4 so far & not much fun.
          • SAZ911
            • Mar 2013
            • 193
            Dear all,
            Hi,
            had this problem a few times, the fix that works for me is quite a process, but worked every time.
            we used to suspect the drums, but they are quite reliable even though they dont last long.
            What i did was remove the laser assy and clean it thoroughly, then you will need to clean the ATR Patch sensors. the tedious part is that you will need to remove the toner supply assemblies as they seem to dribble a lot on to the laser shutter Assy and thus toner gets onto the laser glass, there is a bit of work to be done, but it isn't that bad and the machine will love you for it.
            This is what i found was causing those errors for me..........hope this helps
            SAZ911..........
