My test page just came out looking like this [ATTACH=CONFIG]23833[/ATTACH][ATTACH=CONFIG]23834[/ATTACH]
The yellow is faded what would cause this
There are some problems people cant find them easy but your problem is so simple at first sight.
Yello drum unit is the problem.
Remove yellow drum and check the transparent plastic near the drum for any deformation.(lowest side of drum)
If the transparent plastic is ok, the problem is at your blade, inside the drum unit.
Open drum unit,remove drum and clean the are between blade and mag roller with a paper.There must be something dirty there that block the toner to me fully transfered to the drum.
